How to Get the Vagabond Mace in Aion 2: Drops and Crafting Explained
Zarvenirn
Message par Zarvenirn »
The Vagabond Mace is a rare weapon in Aion 2, specifically designed for Cleric classes. This type of mace is a valuable item that offers a decent balance of attack power, accuracy, and defensive stats, making it highly sought after by Clerics in both PvE and PvP activities. It’s a versatile weapon that fits the Cleric’s playstyle well, providing support in combat with its ability to block incoming attacks while dealing solid damage.
Key Stats of the Vagabond Mace
Before you decide whether this item is right for you, it’s important to understand its key stats:
Item Level: 38
Attack: 137 - 176
Accuracy: 100
Critical Hit: 50
Block: 50
Manastone Slots: 2
For most players, these stats make the Vagabond Mace a reliable weapon for Clerics. The attack range (137 - 176) is solid for PvE, and the accuracy of 100 ensures that you’re less likely to miss your hits. The Critical Hit and Block stats are especially useful when dealing with tougher enemies, providing both offensive and defensive bonuses. The 2 Manastone Slots also offer some flexibility in customizing the weapon to suit your needs.
How to Obtain the Vagabond Mace
The Vagabond Mace can be obtained through the Abyss Drop. This means that you’ll need to participate in certain Abyss-based activities or PvP events to have a chance at acquiring it. Abyss drops can be somewhat random, so it may take a few attempts to get the item. Most players tend to farm these drops during Abyss runs or group activities.
If you're looking to speed up the process, buying Aion 2 gold online can help you secure some extra resources to purchase the mace if you don’t want to rely on the drop rate. However, many players prefer to earn their gear through the game’s progression system.
How to Craft the Vagabond Mace
If you prefer crafting over farming or purchasing, the Vagabond Mace can also be crafted. Here's the list of materials you’ll need to craft this weapon:
Artisan's Splendent Sapphire Ring x 3
Artisan's Ultimate Refining Stone x 6
Enhanced Durable Balaur Scale x 16
Wrathful Mind x 2
Wrathful Will x 4
Wrathful Ego x 8
Radiant Sapphire Gemstone x 13
Radiant Odyle x 8
Crafting the Vagabond Mace requires a bit of a grind. Most players tend to gather these materials over time, especially the rarer items like Enhanced Durable Balaur Scales and Wrathful materials. These materials can be acquired through various activities like questing, gathering, and participating in high-level events. If you’re looking to gather these materials faster, consider grouping up with other players or using your Manastones to enhance your gear to make farming more efficient.
How to Use the Vagabond Mace Effectively
As a Cleric, the Vagabond Mace is your go-to weapon for both offense and defense. It’s built to be effective in PvE combat, where you might need to deal with high damage-dealing monsters, and in PvP, where you could face off against other players. The Critical Hit stat will help you deal more damage, while the Block stat allows you to defend yourself when enemies get too close.
In PvE, Clerics usually use their mace in combination with healing abilities and buffs to keep their allies alive while dealing damage to enemies. The added accuracy will ensure that your attacks land more consistently, and the critical hits make your attacks more effective against tougher bosses or high-health enemies.
In PvP, the Vagabond Mace allows you to play a more active role in combat. While Clerics are often seen as support characters, you’ll be able to hold your own in fights thanks to the balance of attack power and defensive stats. The Block stat can especially come in handy when you’re dealing with enemy damage dealers.
Is the Vagabond Mace Worth Crafting or Buying?
The Vagabond Mace is considered a high-tier item for Clerics in Aion 2. While it’s not the best weapon in the game, it is certainly worth having if you're serious about your Cleric’s progression. It’s especially valuable because it offers a good mix of damage and defense, making it a versatile option for various in-game scenarios.
For PvE players, the Vagabond Mace can help you deal more damage while staying alive longer. For PvP players, it provides the right balance of offense and defense to help you survive the heat of combat while still contributing to your team’s damage.
The Vagabond Mace is a solid weapon for Clerics in Aion 2, offering a good mix of offensive and defensive stats. Whether you choose to obtain it through drops or crafting, it’s a useful tool for both PvE and PvP. If you’re looking to improve your gameplay, this mace is a valuable addition to your arsenal. Make sure to take advantage of its accuracy, critical hit, and block stats to maximize your effectiveness in different situations.
