fonctionnement aléatoire volet roulant WAREMA
Posté : 01 avr. 2025, 11:42
par emile1412
après changement du condensateur du moteur WAREMA ref :W-RT8/17 , le volet roulant a fonctionné 3 jours . et maintenant il est de nouveau à l'arret.
après une coupure elec de 2 ,3 minutes , il a remarché 1 jour , depuis il ne fonctionne plus. on a changé les pile de la télécommande, ça ne va pas mieux.
faut il changer le moteur complet , ou la télécommande, ou autre chose. merci de m'aider dans ma recherche.
WAREMA roller shutter not working
Posté : 11 août 2025, 11:53
par Dr_ava_shamban
That's a frustrating situation to be in. It sounds like you've already tried some basic troubleshooting steps, which is great.
Since the motor worked for a short period after you changed the capacitor, it's possible that the issue is still related to the motor or the capacitor itself. However, because it stopped working again, it could also be an issue with the remote control or the receiver.
Before replacing the entire unit, it might be a good idea to double-check all the connections and possibly try to reset the motor according to the manufacturer's instructions. If the problem persists, consulting with a professional who is familiar with WAREMA systems could help diagnose the issue accurately.
