Rsorder Old School RuneScape: Complete Guide to the Forsaken Tower Quest
Posté : 24 janv. 2026, 04:13
If you’re looking to unlock quick transportation around Lovakengj, earn early Mining and Smithing experience, and gain a helpful teleport for your Kourend adventures, the Forsaken Tower quest is a perfect early-game task with OSRS gold. This quest provides several useful rewards, including free Lovakengj minecart travel, 500 Mining and Smithing XP, the Jewellery of Jubilation page for your Kharedst’s Memoirs, the ability to recolor your Graceful outfit to a yellow-orange variant, and 1 quest point.
The only requirement before starting is completion of Client of Kourend, and there are no skill requirements. Although no items are required, bringing a few supplies makes the quest smoother. Recommended items include:
· 100 coins for minecart travel
· Anti-poison or super anti-poison
· 1 stamina potion
· 8-10 pieces of high-healing food (roughly 160 total HP)
· Kharedst’s Memoirs (optional, to add your page afterward)
· Games necklace
· Battlefront teleport
· Xeric’s Talisman (optional time-saver)
Getting to the Quest Start
Begin the quest by heading to the Lovakengj Assembly, located west of the Lovakengj bank. You can reach the area easily by:
· Using a Xeric’s Talisman → Inferno teleport, then running south, or
· Using a Games Necklace → Wintertodt Camp, running south-east to the minecart station, traveling to Lovakengj, then running northwest.
Speak with Lady Vulcana Lovakengj and the councillor inside the assembly. Select Yes to begin the Forsaken Tower quest.
Meeting Ignisia and Andor
Teleport using your games necklace to the Wintertodt Camp, then run northeast to find Ignisia. After cycling through her dialogue options, head slightly west to find the dwarf Andor, who reveals that the Wintertodt door has been sabotaged. He can repair it-if you retrieve Den’s Hammer.
Your next objective is the Forsaken Tower, located northeast of the Battlefront. Use your Battlefront teleport, run east through the soldiers' camp, then take the northern fork along the winding path until you reach the tower.
Puzzle 1: The Power Grid
Enter the tower and inspect the display case near the entrance to reveal four puzzles. Climb down the ladder directly behind it. Open the northeast door and search the crate to obtain a generator crank. Use the crank on the steam generator in the central room to activate it.
Next, inspect the power grid to the north. You’ll face a 7×7 tile rotation puzzle. Rotate each tile-left or right-to match the proper layout. When all pieces are aligned, the puzzle auto-completes.
Puzzle 2: Coolant Jugs and Furnace Activation
Climb back to the ground floor and head into the back room. Search the cupboards for a tinderbox, 5-gallon jug, and 8-gallon jug.
Your goal is to measure exactly 4 gallons into the 5-gallon jug. Follow this sequence:
1. Fill the 5-gallon jug from the coolant dispenser.
2. Pour it into the 8-gallon jug.
3. Repeat the process until the 8-gallon jug is full, then empty it.
4. Continue transferring coolant until the 5-gallon jug contains exactly 4 gallons.
Use the jug on the furnace coolant, then light the furnace with your tinderbox to complete the second puzzle.
Puzzle 3: Identifying the Cleansing Fluid
Climb upstairs. Search the cupboard on the east wall to obtain old notes. The phrase “cleansing fluid” appears in one of five random positions. Each position corresponds to one of the five unknown fluids on the nearby table.
Match the location of the phrase to the correct fluid number, then use the fluid on the refinery. If you chose wrong, you’ll take damage and be poisoned-heal and try again.
Puzzle 4: Pylon Ring Transfer
Climb to the tower’s top floor where three energy pylons stand. Your task is to transfer the discs so that all four end up stacked on the middle pylon, following the rules of a Tower of Hanoi puzzle. After completing the sequence, the final puzzle ends.
Completing the Quest
Return to the ground floor and retrieve Den’s Hammer from the display case. Teleport back to Wintertodt Camp and give the hammer to Andor. After the conversation, travel via minecart back to Lovakengj and speak with Lady Vulcana to finish the quest.
With the quest complete, use your Jewellery of Jubilation to buy OSRS gold page on your Kharedst’s Memoirs and unlock a new teleport just northeast of Lovakengj bank-perfect for future adventures.
· 1 stamina potion
· Games necklace
