Arc Raiders: The Essential Guide to Duct Tape and Its Recycling
Zarvenirn
Message par Zarvenirn »
What is Duct Tape in Arc Raiders?
Duct Tape is an Uncommon item used primarily in crafting, but it’s also important for recycling and salvaging. It’s a versatile material that can be used to craft various weapon mods and components. In its basic form, it doesn't offer much by itself, but its utility lies in the items you can create or break it down into.
What Can You Craft with Duct Tape?
Duct Tape is integral to crafting several useful mods in Arc Raiders. Some of the key mods that require Duct Tape are:
Angled Grips (I, II, III)
Stable Stocks (I, II, III)
Lightweight and Padded Stocks
Vertical Grips (I, II, III)
These mods enhance the performance of your weapons, whether you're looking for improved recoil control or better stability. For instance, the Angled Grip I requires 1 Duct Tape and 6 Plastic Parts. Higher-tier grips, such as Angled Grip II and III, need progressively more Duct Tape and other materials like Mechanical Components and Mod Components.
Duct Tape also plays a role in crafting weapon stocks, such as the Lightweight Stock and Padded Stock, which can improve weapon handling and stability in combat. Whether you're using a vertical grip to stabilize your aim or a stock to reduce recoil, Duct Tape is a key ingredient in these upgrades.
How to Acquire Duct Tape?
Duct Tape is relatively easy to find, but it’s not as common as some other materials. Here are the main ways to get Duct Tape in Arc Raiders:
Scavenging: You can find Duct Tape while scavenging in various locations.
Recycling: You can also recycle certain items to obtain Duct Tape, especially those items that are no longer useful to you.
Purchasing from Celeste: Celeste, one of the in-game vendors, sells Duct Tape. This can be a reliable option if you’re short on this material and want to stock up.
How to Recycle Duct Tape?
Recycling is a great way to get more out of your resources. If you have extra Duct Tape that you're not using, you can recycle it into Fabric, a crafting material that’s also valuable for creating other items. Here’s the basic breakdown:
Recycling Duct Tape: Yields 3 Fabric.
Salvaging Duct Tape: Yields 1 Fabric.
Recycling is an efficient way to make sure you're using your resources to their fullest, especially when you're low on certain materials. Whether you're building mods or crafting other important items, recycling Duct Tape can help you get the materials you need for your next project.
Can You Recycle Items into Duct Tape?
Yes, you can recycle certain items to get Duct Tape back. For example, high-tier grips and stocks like Angled Grip II or Vertical Grip III can be recycled into Duct Tape. Here's a breakdown:
Angled Grip II: Recycles into 1 Duct Tape.
Angled Grip III: Recycles into 2 Duct Tape.
Padded Stock: Recycles into 1 Duct Tape.
This makes Duct Tape somewhat renewable, especially if you’ve already crafted several high-tier items that you no longer need. Recycling is especially useful when you want to optimize your materials and gain more useful resources without having to go out and scavenge.
Crafting with Duct Tape: What Should You Make First?
As a new player, it can be tempting to craft everything you can with Duct Tape, but it’s better to focus on specific mods that’ll help you survive longer and improve your weapon loadout. Here are some recommended crafting priorities:
1. Angled Grip I
Materials: 6 Plastic Parts, 1 Duct Tape.
Why Craft It?: This is one of the first grips you’ll need to stabilize your weapons early in the game. It’ll help with recoil, making your shots more accurate.
2. Stable Stock I
Materials: 6 Rubber Parts, 1 Duct Tape.
Why Craft It?: Stability is key when you’re on the move, and this stock helps make your weapon handling smoother. It’s a solid early game mod.
3. Vertical Grip I
Why Craft It?: Similar to the angled grip, this vertical grip improves stability and reduces recoil, making it a great option for players who rely on steady shots.
As you progress, you’ll unlock better versions of these mods, and you’ll need more Duct Tape to craft them. Focus on upgrading these key mods, especially the Angled and Vertical Grips, to make your weapons more manageable and effective in the field.
Should I Buy Cheap ARC Raiders Blueprints from Verified Sellers?
As you advance in Arc Raiders, acquiring blueprints for higher-tier mods becomes essential. While you can always craft these mods on your own, buying cheap ARC Raiders blueprints from verified sellers on U4N can save you time and resources, allowing you to focus on other aspects of the game. Purchasing these blueprints is particularly helpful when you want to skip the grind of collecting materials or crafting certain items. Just make sure to buy from verified sellers to avoid scams and ensure you're getting quality blueprints.
Duct Tape may seem like a simple, everyday item, but in Arc Raiders, it’s a vital part of your crafting and recycling strategy. Whether you're upgrading weapons with grips and stocks or recycling for additional materials, understanding how to effectively use Duct Tape can make a big difference in your survival and success.
Competitive Edge: buy ARC Raiders Account at U4N
