Arc Raiders: Dam Testing Annex Key – Practical Questions Answered
Zarvenirn
Message par Zarvenirn »
What is the Dam Testing Annex Key used for?
The Dam Testing Annex Key unlocks doors inside the Testing Annex building on the Dam Battlegrounds map. The building has two locked doors at ground level. One door is on the south side of the building, and the other is on the east side.
Each key opens only one door. If you want to open both doors in a single raid, you must bring two keys. Most players do not do this, because of weight, inventory risk, and the fact that the loot behind the doors is usually similar.
In practice, most players open one door, loot quickly, and leave the area.
Where exactly is the Testing Annex, and why is it risky?
The Testing Annex is part of the Dam Battlegrounds and is not hidden. It is a known point of interest, which means other players expect activity there.
In real matches, the danger does not come from the door itself, but from timing. The building is often passed through by squads rotating between objectives. Opening the door makes noise, and players who hear it may wait outside rather than push immediately.
If you open the door early in a match, the risk is usually lower. Late-game openings are much more dangerous, especially when extraction routes funnel people past the dam.
What kind of loot is actually inside the locked rooms?
This is one of the most common questions. The short answer is: useful, but not guaranteed high value.
Inside the locked rooms you usually find standard loot containers such as lockers, drawers, and filing cabinets. These can spawn crafting materials, weapon parts, and sometimes blueprints. You are not guaranteed rare weapons or top-tier items every time.
From experience, the value comes from consistency. Over many runs, the annex rooms provide steady materials rather than jackpot drops. Players expecting legendary-tier loot every time are usually disappointed.
Is the key worth keeping or should you sell it?
The key sells for a modest amount of coins. Selling it is a safe option if you are short on inventory space or do not plan to run Dam Battlegrounds soon.
However, in practice, players who regularly run the dam get more long-term value from using the key rather than selling it. The weight is low, and the loot can support crafting and progression over time.
If you are early in progression and avoiding risky zones, selling is reasonable. If you are comfortable fighting or disengaging around the dam, using it is usually better.
How do experienced players use the key safely?
Most experienced players follow a few unwritten rules:
They do not rush straight to the Testing Annex at match start unless they spawn close. They listen before opening the door. If there is active gunfire nearby, they often wait or skip the door entirely.
Once the door is opened, looting is fast. No sorting, no standing still. Items are grabbed, and inventory decisions are made later in a safer area.
If another player shows up mid-loot, many veterans disengage rather than fight inside the small room. The space favors ambushes, not fair fights.
Can you open the door and come back later?
No. Once you leave the area, you should assume someone else may enter, especially if the door remains open. In real matches, unlocked doors act as signals to other players that someone has been there recently.
If you open the door, commit to looting immediately. Leaving and returning later rarely works out.
How do players usually obtain the Dam Testing Annex Key?
There are two common ways.
The first is quest completion. One of the early quests rewards a single key, which is how many players first encounter it.
The second is scavenging. The key can appear in standard loot containers like lockers, drawers, and filing cabinets. It is rare, but not extremely rare. Players who loot methodically across multiple maps will see it again over time.
It is not something most players farm directly. It appears naturally if you play consistently.
Does carrying the key change how other players behave?
Indirectly, yes. If you are visibly moving toward the Testing Annex, experienced players may assume you have a key. This can lead to ambushes near entrances.
That is why many players approach the building from unusual angles or wait until nearby squads have moved on. Some even clear the area first, then open the door once it feels quiet.
This behavior comes from experience, not mechanics, but it matters.
Is the loot good enough for blueprint progression?
For many players, yes, over time. The annex rooms are one of many places that feed into blueprint and crafting progress. They are not a shortcut.
Some players who focus heavily on progression outside normal raids look for alternatives, including trading or systems outside the game economy. Discussions around things like buy arc raiders blueprints for ps4 come up in that context, usually from players trying to save time. Inside the game itself, the Testing Annex remains a slow but steady source.
Should solo players use the key, or is it better for squads?
Solo players can absolutely use the key, but they need to be more cautious. The small rooms can trap you if a squad pushes while you are inside.
In practice, solo players do best by opening the door, looting only the closest containers, and leaving immediately. Squads can afford to stay longer because one player can watch the entrance.
If you are solo and unsure, selling the key is not a mistake.
Common mistakes players make with this key
One common mistake is carrying the key across multiple raids “waiting for the right time.” This increases the chance of losing it to a random death.
Another mistake is bringing the key but forgetting to adjust playstyle. The key is only useful if you actually plan to go to the annex.
Finally, some players expect the key to change their match outcome. It will not. It is a small advantage, not a win condition.
Final thoughts from regular use
The Dam Testing Annex Key is a practical item, not a special one. It rewards awareness, timing, and discipline more than combat skill.
Players who treat it as routine loot tend to benefit from it. Players who treat it as something precious often lose it without ever using it.
Snap Hook | All Platform
