Mmoexp CFB 25 Coins: Use Touch and Timing for Deeper Throws
reinebdyfu
Message par reinebdyfu »
Use Touch and Timing for Deeper Throws:
Longer throws require more finesse than simple slant or short routes. For deep passes, it's crucial to CFB 25 Coins use the correct amount of touch and timing, placing the ball ahead of your receiver’s route.
With Placement and Accuracy, you’ll be able to throw a deep ball that lands perfectly in stride, enabling your receiver to continue running without losing speed or having to adjust.
Utilize the Right Stick for Placement:
You can use the right stick on your controller to influence where you throw the ball:
Up: Leads the receiver deeper down the field or over their shoulder.
Down: Throws the ball short or low to the ground.
Left/Right: Places the ball toward the sideline, outside of the defender's coverage.
By combining these directional movements with buy NCAA Football 25 Coins Placement and Accuracy, you can further control where your throw lands.
