Fallout 76 Items: 22 Weapons That Perform Best in PvP
Posté : 12 juil. 2025, 05:26
PvP in Fallout 76 isn't just about who has the highest level or the flashiest gear. It's about using the right tools for the right situations—and knowing how to maximize their impact. Whether you're roaming the Wasteland for Workshop control or facing down another player in Daily Ops spillover, having the best Fallout 76 Items for PvP can make all the difference. Here are 22 weapons that consistently deliver in player-versus-player combat.
1. Bloodied Fixer
With high stealth damage and bonuses to movement speed while sneaking, a Bloodied Fixer with crit perks can absolutely melt opponents before they see you coming.
2. Anti-Armor Handmade Rifle
This classic weapon remains popular for a reason—especially with the anti-armor prefix, which ignores a huge chunk of your enemy's defenses.
3. Quad Railway Rifle
A brutal close-range weapon that, when modded right, can unload an insane burst of damage. Quad ammo capacity means less reloading during a fight.
4. Vampire’s Combat Shotgun
In fast-paced PvP, survivability is huge. A Vampire’s Combat Shotgun can keep you alive longer with health regen on hit, especially when paired with tanky armor.
5. Bloodied Lever Action Rifle
Great for sneaky builds, this weapon works beautifully in VATS-heavy builds, especially when your health is low and damage is maxed out.
6. Instigating Gauss Shotgun
If you’re looking to end fights quickly, this is your tool. The first shot deals double damage if the opponent is at full health—perfect for ambushes.
7. Quad Tesla Rifle
While usually seen in PvE, this weapon can be devastating in PvP when used correctly, especially in tight spaces and with the right perks.
8. Bloodied 10mm Submachine Gun
With high rate of fire and great mobility, the 10mm SMG is ideal for VATS builds. Pair it with crit-enhancing perks for serious output.
9. Executioner’s Gatling Plasma
Especially effective in team fights, this weapon ramps up its damage once your target hits half health. Great for wearing down enemies quickly.
10. Anti-Armor Gauss Minigun
Shreds through power armor and heavy builds. When fully charged, the damage spikes dramatically.
11. Junkie’s Gatling Gun
If you’re running multiple addictions, this thing becomes a wrecking machine. High base damage and great ammo economy.
12. Bloodied Explosive Pipe Revolver
With the right setup, this underrated weapon can be a crit beast. Lightweight, fast, and punishing when built right.
13. Quad Ultracite Laser Rifle
Rare but effective in PvP, especially with the beam splitter mod and high VATS efficiency. Quad ammo keeps it firing longer.
14. Vampire’s Plasma Caster
This heavy weapon is great for both burst and sustain, especially if you need healing mid-fight. It’s slow, but hits like a truck.
15. Two Shot Explosive Combat Rifle
A legacy favorite that still performs in current PvP metas. If you still have one, it’s a solid pick for raw damage.
16. Instigating Plasma Rifle
An excellent opener in PvP if you can land the first shot. Pairs well with stealth builds or ambush tactics.
17. Bloodied Gauss Rifle
With crit builds, the Bloodied Gauss Rifle offers fast-charging devastation. Just stay at low health to get the full value.
18. Furious Crossbow
Not everyone’s first pick, but against teams or for longer engagements, the Furious effect (stacking damage) makes it surprisingly effective.
19. Mutant’s Western Revolver
When you’re running mutations, this is an elegant sidearm that hits hard. Works well in agility-based builds.
20. Anti-Armor Double-Barrel Shotgun
Perfect for clearing corners and controlling objectives. Short range, but massive stopping power.
21. Vampire’s Gatling Laser
Sustained fire and built-in healing make this a great support weapon during team fights.
22. Executioner’s Super Sledge
Melee is harder to pull off in PvP, but with the Executioner’s effect and a jetpack for mobility, this thing can ruin someone's day fast.
Choosing the right weapon isn’t just about raw stats—it’s about synergy with your build, armor, perks, and situation. Remember to experiment with legendary mods and test different combinations in real skirmishes. Don't forget to keep a few caps on hand in case you need to Buy Fallout 76 Caps and restock your stash or repair gear.
PvP in Fallout 76 is all about preparation. So stock up on the best Fallout 76 Items, fine-tune your loadout, and hit the battlefield ready.
1. Bloodied Fixer
7. Quad Tesla Rifle
