U4GM - 7 Tricks Elden Ring Rune Duplication
Posté : 02 juin 2025, 09:45
If you've ventured deep into the Lands Between, you know how vital *Elden Ring Runes* are. As someone who has spent hundreds of hours exploring dungeons, toppling bosses, and pushing through New Game Plus cycles, I’ve come to understand that runes are more than just a currency—they’re the foundation of progress. Whether you're upgrading gear or leveling up your character, gathering runes is a never-ending pursuit. While there are many legit ways to earn them, there are also some clever tricks to duplicate runes that can ease the grind.
Here are seven rune duplication methods I’ve personally used, tested, and refined throughout my gameplay journey:
**1. Co-Op Death Loop Trick**
This method works best with a friend. You drop a stack of valuable consumable runes (like Hero’s Runes), have your friend pick them up, and then force a game crash or rollback through a timed network disconnect. When you return, the game reverts to the last save point, and both players retain the runes. Timing is everything here, and practice makes perfect.
**2. Save File Duplication (Offline Mode)**
Before using consumable runes, back up your save data. After consuming them, reload the backup and repeat. This method is particularly effective on PC and PlayStation systems where save backups can be managed externally. I’ve used this trick early on to stack millions of runes in just a few hours.
**3. Torrent Jump & Fall Exploit**
There are certain areas in the game—especially in the underground sections—where jumping off ledges with Torrent causes the game to reward you with runes if enemies below fall and die from chaining aggro. I found a spot in Mohgwyn Palace where this trick helped me farm over 300,000 runes in minutes, with minimal risk.
**4. New Game Plus Rune Stack**
In NG+, you keep all your gear and stats. If you stack consumable runes before restarting and duplicate them using earlier tricks, you’ll begin the new cycle with immense power. I once entered NG+ with over 50 million runes banked and it felt like a cheat code.
**5. Blood-Stained Co-Op Farming**
Some players use blood stains in heavily trafficked areas to find consistent PvP zones. By teaming up with another player to trade kills while using rune-boosting talismans and the Gold-Pickled Fowl Foot, you can generate high rune yields quickly. The key is coordination and a good rune farming partner.
**6. Use of Elden Ring Rune Buy Service (Safely)**
For players short on time or unwilling to risk duplication bugs, an *Elden Ring rune buy service* is a viable alternative. I tested this route through U4GM during a busy work week and received my runes without any account issues. The key here is choosing a reputable provider and staying away from any sketchy marketplaces. Always check community reviews first.
**7. Boss Repetition via Summon and Save Reload**
If you summon a boss through a friend’s game repeatedly, and both of you have save backups, you can effectively farm the same boss rewards again and again. It requires tight timing and understanding of save sync, but it’s especially effective for mid-game rune grinding.
In conclusion, while duplication can be a controversial topic, it often comes down to how you use these tricks—are you skipping content, or just leveling the playing field for a tough build? Personally, I’ve always valued efficiency, especially when testing new builds or preparing for PvP. Whether you're grinding naturally or using shortcuts, *Elden Ring Runes* remain the key to unlocking the full depth of the game. If you're low on time, the *Elden Ring rune buy service* route offers a dependable and safe shortcut—just remember to use it wisely.
Player Picks:Elden Ring Runes Glitch: What Still Works in 2025
