In Marvel Rivals, environmental hazards are more than just flashy set pieces — they’re game-changers. Whether you’re fighting across rooftops, dodging laser traps, or collapsing structures beneath your enemies, knowing how to use these features strategically can give you a serious edge. This guide breaks down seven of the best ways to use environmental hazards to win matches in Marvel Rivals.
1. Luring Opponents Into Explosive Zones
Certain maps feature barrels, generators, or unstable terrain that explode when damaged. Lure aggressive enemies into these areas and trigger the hazard for burst damage. This tactic is especially useful when playing high-risk, close-range heroes like those featured in the Moon Knight - Fist of Vengeance Bundle.
2. Breaking Cover With Collapsible Structures
Many maps include destructible cover — like walls or platforms — that can be broken by heavy attacks or explosive abilities. Time your strikes to remove enemy protection at key moments. This forces them into open territory where your team can clean up quickly.
3. Using Vertical Hazards for Displacement
Maps like Techno-City or Stark Foundry often include jump pads, gravity lifts, or falling platforms. Use these to displace enemies from strong positions or launch them into traps. This is an advanced strategy that pairs well with agile characters, especially those you’ll find when you buy Marvel Rivals Bundles that focus on mobility and area control.
4. Triggering Chain Reactions for Area Denial
Some hazards don’t just deal damage — they cause chain reactions. Hit a central structure or trigger point to cause nearby objects to collapse or explode, creating zones of denial. Perfect for controlling choke points and breaking up enemy formations during team fights.
5. Cornering with Energy Fields and Traps
Electric floors, fire zones, or laser barriers can be used to limit enemy movement. Combine these with crowd control abilities to trap enemies inside these zones. Characters like Moon Knight, with stealth and gap-closing abilities, can use this setup to isolate and eliminate targets efficiently.
6. Turning Hazards Into Escape Routes
Don’t just use hazards offensively — you can use them to escape. Knock down a bridge behind you, zip through a moving platform, or block a hallway with falling debris. Smart use of the environment can save your life when you’re outnumbered or retreating with low HP.
7. Syncing Ultimate Abilities With Destructible Features
Some ultimates can wipe out hazards and structures, or combo with them for devastating effects. Sync your team’s ults with environmental changes for a perfect team wipe. This tactic is often overlooked but can flip a match when executed well.
Environmental hazards reward players who understand both the map and the mechanics. Whether you’re a new player or a veteran experimenting with bundles like the Moon Knight - Fist of Vengeance Bundle, learning how to use the battlefield itself as a weapon will make you far more lethal.
Looking to level up your roster? Don’t forget to buy Marvel Rivals Bundles to unlock more heroes and skins that suit your strategic playstyle.
U4GM - 7 Best Uses of Environmental Hazards in Marvel Rivals
BlazingPhoenix
